Chokes for bldc card
Discussion in 'The Projects Forum' started by jm-a, Feb 24, 2011.
  1. jm-a
    Thread Starter Active Member
    Oct 20, 2010
    105
    Hi all
    I'm searching how to calculate L1 to L3 on draft joined.
    I found some good links about maths for stray cable, but none about chokes or reactors or ? .
    Real value of SMD choke on pcb is 680 µF, so read these datasheet, and a few questions, as usual.
    For this use, what's the best component, shielded i think, but about Ic value; better use for Ic ≈ 1 A or more than lower than 1A ?
    Thanks a lot.
    jm
