Choke = Inductor?
Discussion in 'General Electronics Chat' started by ihayles, Oct 2, 2010.
  1. ihayles
    Sep 24, 2010
    I don't get chokes. I see them in EMI filters, typically, but if I analyze the differential equation for the choke, I basically get the same thing I'd expect for an inductor, but with L=L1+L2±M.
    So why the special treatment? It's just a coupled inductor, right? The only thing that makes a bit of sense is that:
    1) Greater inductance per material by coupling two inductors
    2) "Tunable" inductance based on winding and coupling technique, easier manufacturability per a given inductance value
    Any input on what's special about a choke vs. an inductor? Why do I always see them in EMI filters...I must be missing something. Inductors in EMI filters are few and far between.
  2. Ghar
    Mar 8, 2010
    655
    73
    Are you talking about a configuration like this?
    That's a common-mode choke.
    For differential signals, like your signals or power, the common-mode choke ideally has no effect. That is, if you go around the loop you get:
    Vsrc - Vchoke - Vload + Vchoke = 0
    Vsrc = Vload
    The 1:1 coupling makes the voltage across the choke cancel out for differential situations. Similarly differential signals don't saturate the core material because of this effect. This means you can have a small and very high permeability core material even with large DC currents.
    For common mode current the choke appears as simply an inductor.
    Common mode is a fairly abnormal situation you don't often think about and it's key in EMI, hence the use of common mode chokes in EMI filters.
    Common mode is when both wires are carrying current in the same direction, the loop being closed by parasitic capacitance or an unintended conductive path somewhere else in the circuit.
    This would be what the choke is doing for common mode signals:
    That schematic there could be showing a ground loop for example. The choke would reduce the ground loop current.
    ihayles likes this.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Choke is indeed another name for inductor, they are meant to use for power supply circuits. I have several in my parts box. They use resistor color codes to mark the values.
    In general the chokes that are the same sizes as resistors are pretty high resistance, the wires inside are smaller diameter.
  4. mik3
    Feb 4, 2008
    4,846
    63
    They are called chokes because they 'choke' (filter) noise in circuits.
  5. sceadwian
    Jun 1, 2009
    499
    37
    For a real world example why are there cars trucks and vans? They all have four wheels.. Application changes the appropriate word.
  6. ihayles
    Sep 24, 2010
    Thanks; this helps.
    For the common mode signal case, I did KVL on the top and bottom branches...
    The equations are...
    I had resistors in there to ground, but it's even easier to see that if you let Rp=Rn=0, then In and Ip are as if the choke is just an inductor. Let M = 0 and the equations have the same form.
    The the differential mode case, I did KVL around the loop...
    The equation and analysis for perfect coupling with Lp=Ln shows what you mention...
    So, really, chokes should be perfectly coupled with Lp=Ln. In this case, they're different than simple inductors in that the stop common-mode signals, but let differential ones pass, as Ghar mentioned.
    Thanks for pointing me in the right direction!
  7. ihayles
    Sep 24, 2010
    Indeed, inductors also are great for the city and commuting, saving you fuel, while chokes are great for hauling your kids and boat around while on vacation!
  8. Ghar
    Mar 8, 2010
    655
    73
    You're welcome, glad you worked it out.
    It depends on the situation but you often don't want perfect coupling in a common mode choke so that you also get some amount of differential filtering.
    EMI filters generally need to take care of both differential and common mode noise.
