Choice of opamp for analog RF filter
Peter Pan
Joined Mar 24, 2005
122
Hello All :)I need to design a band-pass filter amplifiyng signals whose frequencies are between 4 and 5 MHz and rejecting the rest, especially at frequencies below 4MHz. Gain for the band should be about 20 dB.Please, could you advise me an active unit (opamp preferably) for this filter keeping in mind that there is only +12V power supply and ground available.Thank you.
Papabravo
Joined Feb 24, 2006
21,225
I'm not sure there is an appropriate choice of an opamp to operate at those frequencies. Operating single supply definitely limits your choices. I could be wrong though, time and technology do march on.
Peter Pan
Joined Mar 24, 2005
122
Thank you, t n k - that opamp is great I sense but a bit out of my budget, unfortunately ...Thanks to Bertus - you've given a very thorough list of opamps and most of these seem suitable. So, I'm overwhelmed :) Would you suggest any specific opamp? (from your experience, perhaps). I mean to use it in low field NMR amplifier (designed for signals with Larmor frequency about 4.333 MHz). The spectrum of signals (after 3-stage amplifier) is extremely noisy, with plenty of broad unwanted signals between 2 and 4 MHz and below 2 MHz as well. So it's necessary to get rid of them in order to have a cleaner spectrum with strongest peak at Larmor frequency (4.333 MHz in my case).
Peter Pan
Joined Mar 24, 2005
122
I have attached a picture of input (blue trace) and output (red trace) of my amplifier. Output signal has to be filtered out so that a single spectral component at about 4.33 MHz (emphasized by dashed line over it) would dominate in a spectrum and the rest (which is unwanted) has to be significantly attenuated or removed (ideally).
It's certainly possible to implement a 4.3 MHz active bandpass filter using some of the excellent fast op-amps available today, but it's not without its problems, and one of the circuits Bertus suggests would be a safer bet. Be judicious in the choice of inductor type, as the core needs to operate at the maximum frequency of interest - this may be 100s of MHz for a 4 MHz centre frequency. The caps will be less critical, but they should still be chosen for minimum equivalent series inductance (ESL).
If you want to go down the active filter route, then the figure of merit for choosing the op-amp (all other things being considered) is the gain-bandwidth product (GBW) of the device. A specific active filter architecture will have a minimum GBW requirement. These requirement will vary between different architectures, and finding out exactly what is needed is difficult as it's a topic that's conveniently brushed over in most filter textbooks.
bertus
Joined Apr 5, 2008
22,277
When you take a look at the PDF I attached before it says with some types DC - 2 GHz.
At lower frequencies the noise will even be lower.
I think they will work fine.
I have used them in amplifiers for 40 - 860 MHz for cable TV.
Greetings,
Bertus
Peter Pan
Joined Mar 24, 2005
122
Greetings,
Bertus
Yes, I have looked at the file (thank you!) and have not found so far a MMIC from the list which could amplify for 1-10 MHz band. Them seem to be normally used for amplification at higher frequencies - about 0.1 GHz and higher, according to their electrical specifications. At lower frequencies manufacturer does not specifies any gain ...
Peter Pan
Joined Mar 24, 2005
122
Here is the datasheet of the MAR6 that I used for that amplifier.
It also shows how to use it.
Greetings,
Bertus
Thank you, Bertus. It's likely that they will do their job at lower frequencies as well!I just have another question (a bit silly perhaps) - MAR6 is an amplifier ... so how I could use it for filtering?!
bertus
Joined Apr 5, 2008
22,277
You can place the filter before the MAR.
So filter -> MAR -> (second filter -> second MAR , if needed).
The Mar will compensate the filter losses and give some gain.
Greetings,
Bertus
