Be careful about overheating SMDs -- get it onto the board fast! There is such a thing as a SURFboard, a small daughter board designed to hold one or two ICs and just a few surface mount Rs, Ls and Cs. Maybe RadioShack?Originally posted by n9352527@May 21 2006, 10:59 AM
The 18F4550 USB PIC (40DIP) is available in the UK from Farnell (for around £5), I have no idea about the 28SDIP USB one (18F2455?). They are compatible though, only different IO number and flash memory size.
PIC programmer is quite cheap to obtain, or make yourself. And once you've got a programmer or access to one you could burn a small bootloader program so that further programming could be performed through USB link without any programmer (enhanced flash self programming).
I have a conical tip for soldering iron that is excellent for smd soldering. It uses the surface tension insode the cone to dispense just the right amount of molten solder and prevent bridging and too much solder. I'm pretty much able to solder most of the smd components/packages manually except for things like BGA packages where the pins are not accessible. It is not that expensive to buy, but you would also need additional flux to work with it (and probably flux cleaner too).
[post=17260]Quoted post[/post]
