Chip dictionary
Discussion in 'Programmer's Corner' started by Robin Mitchell, Nov 4, 2010.
  1. Robin Mitchell
    Oct 25, 2009
    738
    207
    Hi everyone
    Dont think this exists but im sick of having to open different datasheets for different components so im making a piece of software that has many IC's that you can select and instantly shows the pin layout
    Robin
    Its called ChipDIC
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    That would be pretty handy.
    I mostly use the online datasheet databases, as they are most up to date.
    Trying to get all the datasheets as PDF or other format may be the large hurdle. Doing pinouts only would be nifty, but the same data problem exists for the sheer number of devices available.
  3. spinnaker
    Oct 29, 2009
    5,076
    1,176
    Cool idea but I think this would be a big project. You would have to redraw all of the chips. That is a lot of work.
  4. maxpower097
    Feb 20, 2009
    795
    388
    I think they exist they are just all out of date or incomplete. That would be a great community project. Even justa part number, name, pinout and pin name would be cool. Great idea.
  5. Robin Mitchell
    Oct 25, 2009
    738
    207
    well so far i have a program that just shows the pinouts. It only contains one chip, 4008 :p. Every chip is saved in a text file (on its own) and you just select a type of chip. So first, 4000 series, then 4008 :)
  6. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
  7. Robin Mitchell
    Oct 25, 2009
    738
    207
    bertus that website is just awful :p
    A program with a proper layout would be much better!
    This is just confusing!
  8. jpanhalt
    Jan 18, 2008
    5,699
    909
    Isn't that what schematic capture PCB programs do? Eagle certainly does it.
    John
  9. Mr Bill Gates
    Nov 2, 2010
  10. retched
    Dec 5, 2009
    5,201
    313
    Mr. Gates, loosewire is trying to get hold of you.
    As for the pinout database program...I would use it.
  11. Mr Bill Gates
    Nov 2, 2010
    Loosewire has my number
  12. nerdegutta
    Dec 15, 2009
    2,565
    806
    It would be nice if one of the features were a comparison table of different transistors, and their substitutes, the same for diodes. Then I would buy it. :)
    Maybe there is a database like that out there I haven't found... :confused:
  13. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
  14. Wendy
    Mar 24, 2008
    20,772
    2,540
    How I do it with PaintCAD, it is a forever problem...
  15. Robin Mitchell
    Oct 25, 2009
    738
    207
    Do you know what i like about bertus, he is the most polite :p
    I think i will like to persu this, seems a worth while project. What i want is not 100 chips on one page, i have to go through and look for it, i want a list that can do a search and instantly show the pinouts. An interactive program which you can include your own IC's as well!
  16. retched
    Dec 5, 2009
    5,201
    313
    You should take it a step further and add spice models for the ICs as you go.
    That way as you lookup the ICs you want, you can also grab the spice model and use it in layouts and simulations...
    Now THAT would be helpful.
  17. spinnaker
    Oct 29, 2009
    5,076
    1,176
    I have been doing some thinking about this project. I think the pin outs don't need to be drawn. I think just a listing with each pin function would do.
    If you still want a graphic representation of the chip then it probably should be generated by your program as opposed to drawing each one free hand and storing the image.
    Or I suppose you could "borrow" the image from the datasheet but that would probably violate some copyright laws.
  18. Robin Mitchell
    Oct 25, 2009
    738
    207
    thats what my program does, it has different default chips from 8 pin to 40 pin. then you just change the pin layout]
    But at the moment im using text graphics:
    Code ( (Unknown Language)):
    1.
    2.    Chip Name here
    3.
    4.      ---------
    5. XXXX|         |XXXX
    6. XXXX|         |XXXX
    7. XXXX|         |XXXX
    8. XXXX|         |XXXX
    9. XXXX|         |XXXX
    10. XXXX|         |XXXX
    11. XXXX|         |XXXX
    12. XXXX|         |XXXX
    13.      ---------
    14.
    15.
    16.
  19. Robin Mitchell
    Oct 25, 2009
    738
    207
    I have the best logo for it :D
  20. retched
    Dec 5, 2009
    5,201
    313
    If you could mouseover the pins and get info, that would be awesome.
