Dear all,
So some of you here will be familiar that I have made posts about Chinese imported parts that did not function correctly when used in a specific arrangement.
I also have two other parts : 74HC14 and 4093
Now I stock these for the sole purpose of their oscillation applications. They have Schmitt trigger inputs which means that they are perfect for RC oscillators (and that they are inverting so the output is at 180 degrees to the input, a requirement for oscillation).
Now, I built my CPU card and fitted one of these Chinese parts and the oscillator did not oscillate. Instead it sat around 2.5V (with a 5V supply). But what was more worrying was how hot the chip got....then it exploded! Surprise surprise
Now if anyone here looked at the parts they would spot that they are not official parts in a second!
"But Robin, its probably your circuit configuration. Im sure your at fault that these parts are fine". Well here is the schematic for the two oscillators:
And with the CPU card I replaced the 74HC14 part with one of my older ones (which is an official part). And guess what happened... The LEDs blinked, the IORQ line on the Z80 was clocking away and the oscillator...was working
So I have a theory and need some guys here to help me with this (those who have experience or knowledge on semi-conductors). I reckon that what is happening is that either some kind of input protection diode is failing or that the internal "MOS" transistors (if they are :/ ), are sitting around the linear region which causes them to explode. Maybe there is poor silicon design so latch up is really easy to get. I also believe this because when the power supply is reduced below 3V feedback circuits have a better chance of working such as the 4013 toggle layout. Maybe the lower voltage is not high enough to cause latch up and ruin the device.
Any thoughts? Anyone here ever seen a chinese silicon piece under a scope?
