Chicken coop door
Discussion in 'The Projects Forum' started by Brad Rustan, Apr 17, 2016.
  1. Brad Rustan
    Apr 17, 2016
    6
    i am trying to automate my chicken coop so if I'm not home the door will open and close on its own. It will be a 12v system. I have a linear actuator to operate the door. It has 2 wires and you reverse the polarity to change direction. I also have 2 timers to send power to the actuator at open and close times. What else do I need to have to wire it and how should I wire the circuit so I don't fry anything? Do I need a DPDT relay? Thanks for the help. I'm new and stumped.
  2. Brad Rustan
    Apr 17, 2016
    6
    These are the timers I'm going to use
  3. Brad Rustan
    Apr 17, 2016
    6
    This is the back
  4. Alec_t
    Sep 17, 2013
    5,980
    1,138
    You do need a DPDT relay (or you could build an electronic equivalent).
    Does the actuator have internal limit switches? If not, you would need to get a couple.
    Have you used the on-site search function to find the other threads here related to coop doors?
    Welcome to AAC!
  5. Brad Rustan
    Apr 17, 2016
    6
  6. Brad Rustan
    Apr 17, 2016
    6
    Thanks. I spent a lot of time trying to figure this out. Most of the posts don't really fit my application. I'm hoping this might work.
  7. Dodgydave
    Jun 22, 2012
    5,166
    775
    Looks ok,ideally you need end limit switches, what happens when the actuator gets to the end of travel and the power is still applied?
  8. Brad Rustan
    Apr 17, 2016
    6
    It is supposed to have internal limit switches.
