Chicken coop door revisited
Discussion in 'The Projects Forum' started by ssafranek, Dec 24, 2015.
  1. ssafranek
    Dec 23, 2015
    12
    Sorry to ask about this again, but I am an absolute zero on electrical stuff. I have a reversible linear actuator that I want to hook up to a chicken door. I have a 12 volt power to connect to the actuator. I need the easiest way to be able to reverse this door. I have an 8 pin dpdt relay. I also have 5 pin spdt relay. Can someone provide clear instructions on what goes where?
    All those squiggly lines don't help me. What goes where? Hook it al up.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Then you post pictures of your actuator connector (with pins labeled), your relay (with pins labeled), your timer or switch (How are you going to tell it to up/down?), your power supply, etc
    Since you seem to want everything done for you so you have to learn nothing in the process, maybe you should just send me the parts, and I will wire it up for you...
  3. Externet
    Nov 29, 2005
    780
    58
    The squiggly lines are the electronics language. For the unskilled not-bilingual, the simplest actions can be somewhat explained with words in English.
    I suggest not to use a linear actuator and relay connections without 'squiggly lines'. A vertically sliding door can be pulled up if a nylon line is pulled up by a 12V motor by winding it on its shaft as if it was a pulley. The "easiest" way to reverse the door (down) is by turning off the motor, and the weight of the door will turn the shaft to unwind the suspending string.
    The motor can be connected to 12V with a series light bulb that permits stalling, or powered by a solar panel that will open at dawn and release by unwinding at dusk.
    ----> https://www.clear.rice.edu/elec201/Book/images/img126.gif
  4. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    IIRC there are at least three previous threads for Coop doors, complete with components and schematics?
    Max.
  5. ssafranek
    Dec 23, 2015
    12
    This is a copy of the actuator. It shuts off automatically when it reaches the end of its extension. It has two wires, not a third.
    I was kidding about the squiggly lines. The problem I have had is that I have seen a host of different suggested wirings, and none of them seem to work for me. My 8 pin DPDT looks like this.
    The diagrams all indicate that power should go to the two unique prongs. After that, I see a host of different opinions. I have tried them and none of them seem to work. I cannot even get the actuator to move up or down when I try them.
    Thanks,:)
  6. ssafranek
    Dec 23, 2015
    12
    I posted the pictures on the response to me below. The on off switch is standard timer switch for lights. I am using a converter plugged into the timer.
    I really appreciate this. I have spent about 10 hours trying to figure this out.
  7. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    Did you apply power directly to the actuator conductors to try it?
    If it does not move with either polarity, test continuity across the two and show the reading.
    Max.
  8. ssafranek
    Dec 23, 2015
    12
    Yes. When I apply power directly to the actuator it moves up and down. I manually switch the wires for one direction and then the other.
    So, the actuator works and the 12 volt converter works and when I apply the + and - to the relay, I can hear and see the relay click.
  9. MikeML
    Oct 2, 2009
    5,451
    1,066
    You cannot make this work the way you propose. The DC power supply must be powered always, because DC power must be available to close the door even when the timer output is off. The timer has to control the DPDT relay, not the 12Vdc power supply.
  10. MikeML
    Oct 2, 2009
    5,451
    1,066
    Reference my post #9: The timer puts out 120Vac when on. To control the DPDT relay, the coil in the relay must be designed to be operated from 120Vac, not 12Vdc.
  11. BReeves
    Member
    Nov 24, 2012
    412
    64
    Not if he uses a 12 volt power supply but doesn't really matter as you posted above the timer needs to reverse the motor not simply apply power.
    Come to think of it he could make this work, when timer is off the relay can close the door with the actuator acting as the limit. When the timer is on the relay is energized reversing the actuator and can stay in that state till the timer turns off and closes the door.
    Look up "reversing a dc motor with a DPDT relay"
  12. ssafranek
    Dec 23, 2015
    12
    Here is a picture of what they say will work:
    I am just unsure what pins of a SPDT they are indicating need to be connected (Com, NO1, NO2, NC1, NC2). Also, I do not understand what the middle Arrow does in this diagram (is it there just for emphasis) and the same for the arrows off the ground on each side. So, how can this be redrawn for a 12 volt power supply and not a battery?
  13. MikeML
    Oct 2, 2009
    5,451
    1,066
    I cant tell, but it sounds like you are agreeing with me???
  14. MikeML
    Oct 2, 2009
    5,451
    1,066
    What the hell is a "Wildlife Timer"?
    Since your actuator has built-in limit switches, then you can do it with one timer, one relay (as long as it has the right coil voltage), one DC power supply, and one actuator.
    Does your timer look like this:
    Are you ready for some squiggly lines?
  15. ssafranek
    Dec 23, 2015
    12
    Here is another one. I even got those same timers, but I cannot figure out which wires go where. It is too jumbled to see what is supposed to go with upload_2015-12-24_11-16-26.png what
  16. ssafranek
    Dec 23, 2015
    12
    Can you draw it out for me or describe it. I think the "wildlife timer" is described as responding to light and darkness.
  17. MikeML
    Oct 2, 2009
    5,451
    1,066
    Answer this question: What powers the timer? 120Vac wall plugin?
  18. ssafranek
    Dec 23, 2015
    12
  19. ssafranek
    Dec 23, 2015
    12
    Yes. Standard AC house current -- I have an extension cord to the coop
  20. MikeML
    Oct 2, 2009
    5,451
    1,066
    Post a link to the relay you have on hand.
