Cherokee Power Supply Datasheet
Discussion in 'The Projects Forum' started by JOELMURP, Dec 7, 2006.
  1. JOELMURP
    Dec 7, 2006
    I've been using the Cherokee International Powersupply model MQT154A1 4A and it's been a while since I've had to re-wire one. I found this forum while searching for a datasheet. The google results directed me to a thread that offered a link to the datasheet... inticing, huh? but when I linked to the forum, there was no sheet to be found. Now I'm registered, and I still can't find the reference from the search.
    If you search for 'mqt154a1 datasheet' on google, it's the first link up.
    Does anyone have the link on them?
    I need to verify amp rating and voltage.
    Joel
  2. beck
    Member
    Nov 27, 2006
    26
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    The Google link may be related to a result from the previous version (type) of the forums, hence that is why you probably wouldn't have been able to obtain the document when you joined.
    Dave
  4. JOELMURP
    Dec 7, 2006
    that link is unusable. i looked at the jameco site, and they only have one cherokee international power supply, but not the one i have.
    thanks though. anyone else?
  5. JOELMURP
    Dec 7, 2006
    any way to dig through to get to it? now that i've joined, there is no result from follwing the link, but there it is... offering content, and being searched...
    it's likely my last ditch. cherokee turned the supply 'end of life' years ago.
    much obliged,
    joel
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
  7. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Like I say, that is not an issue at our end. When the forums changed over we didn't guarantee that you would be able to access everything from the transition. We can try to help you in the way we are now.
    Dave
  8. JOELMURP
    Dec 7, 2006
    yup. that's it. good to know that i came to the right place.
    now i can have some fun!
    j
  9. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Good :)
    It is stored locally on my web space so I will leave it up for a couple of days. I recommend you take a local copy for your purposes. You owe beck a thank since he was the one who found it.
    Dave
