I made a voltmeter recently with ICL7107 and it worked fine while I was calibrating it.. Then I had it connected to a power supply and two times it worked well but yesterday it wouldnt switch on at all.. I found that the 7805 and 7905 regulators were giving only around 3.5v each which used to give 5v correctly in the beginning.. I cant find any problem in the transformer or rectifier but I get only 3.5v each.. Input to the regulators is 7v.. so I used another transformer and gave an input so now output is giving 5v each but my display shows a static number.. Its not dynamic.. Mostly shows 10.88 without load.. Is my IC blown off??? It doesnt move at all.. Connections are ok and how can I confirm before I buy a new IC??? Also what could have happd to the transformer??
