check the logic
Discussion in 'Programmer's Corner' started by moulding machine, Jul 26, 2006.
  1. moulding machine
    Jul 15, 2006
    respected friends,
    pleaz if u can the logic that i have developed for the the PROBLEM that is
    "TWO INPUTS
    X0(enable input)
    x1(disable input)
    THREE OUTPUTS
    Yo,Y1,Y2
    now what i want to do it is"blink the output yo for 10 times then y1 & y2"
    MY LOGIC IS
    TWO CONTACTS XO(NO),X1(NC) IN SERIES WHICH TURNS AUXILIARY FLAG (M0) HIGH
    CONTACT MO TURNS OUTPUT Y0 HIGH
    YO IS COUNTED BY COUNTER C9
    X1(NC) RESETS THE COUNTER C9
    THEN
    X1(NC) TURNS (M1) HIGH
    CONTACT M1 TURNS Y1 HIGH
    Y1 IS COUNTED BY CONTER C9
    X1(NC) RESETS COUNTER C9
    & SO ON FOR THIRD OUTPUT
    i will b highly oblieged
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Perhaps you could give us an idea of what you already have done. Then we can guide you from there.
    Also, is this specifically a programming question? If so, you could also so with giving an idea of the language you wish to use and any development tools you are using, or need to use. I will hazard a guess that you are using a hardware description language of some description.
    Dave
  3. n9352527
    Oct 14, 2005
    1,198
    Ladder for PLC perhaps?
