check the circuit
Discussion in 'Homework Help' started by bhuvanesh, Sep 19, 2014.
  1. bhuvanesh
    Aug 10, 2013
    268
    Do u think the circuit is correct.See from the circuit if the complimented output of 1st f//f is 1 and second normal output is 0.Then whats the one of the input of and gate.The two outputs wires are merged is that correct?
  2. JoeJester
    Apr 26, 2005
    3,390
    1,211
    Where did you get that circuit?
    bhuvanesh likes this.
  3. ScottWang
    Aug 23, 2012
    4,924
    776
    The first /Q will be conflict with the second Q when they are on the different level as one is Low and another is High.
  4. MrCarlos
    Jan 2, 2010
    400
    134
    Hello Bhuvanesh
    And yes, where did you get that circuit ?
    If (A 'Q)=1 and (Q B)=0 we will have 1/2. . . No sorry it's just a joke.
    What we would get is an undefined state.
    but. . . if B can sink more current than A will have a 0.
    Etc.
    That kind of connection is unusual because most of the time we will have a undefined state. also one of the two flip-flops may be damaged.
    Remove that conflicting line. Then try to answer the question that is at the bottom of your picture. The ripple counter shown in fig works as a: .
  5. JoeJester
    Apr 26, 2005
    3,390
    1,211
    With respect to the circuit as drawn, the answer to the question is ... a poorly designed circuit.
    I'm still interested in the source ... but I will offer this observation, if the source is the OP, the problem has been pointed out concerning the AND gate. If it's from the instructor, that's a different story. It is possible the student failed to copy the diagram correctly, thereby the student needs to exercise due diligence when taking notes.
    My crystal ball is in the wizards' shop being updated with new cloudware, so further guessing is futile.
  6. bhuvanesh
    Aug 10, 2013
    268
    answer is mod 5 down counter.
  7. ScottWang
    Aug 23, 2012
    4,924
    776
    The second Q should be cut off from the first /Q.
    For a practical logic IC as 74LS76 or 74HC76, you need to connecting the output of NAND gate to the clear or reset pins, and connecting the set or preset pins to +V.
