Check my answer for a question regarding Thevenin Theorem
Discussion in 'Homework Help' started by Ashenrise, May 12, 2016.
  1. Ashenrise
    May 2, 2016
    This is exactly how my professor formatted the question:
    For the circuit shown below, calculate:
    (a) Thevenin Voltage (Vth)
    (b) Thevenin Resistance Rth
    (c) Load current ( IL )
    this is what I got but I'm not sure what I'm doing wrong:
    Vt= 10.9V - 0.9 V= 10 V
    1. Vth= R2xVt/(R2+R1)
    2. Vth= 600 x 10/600+400= 6000/1000= 6 V
    3. Rth= R1+R2= 400+600= 1kohm
    4. IL= Vth/RL+Rth= 6/1+1= 3mA
  2. HW-nut
    Member
    May 12, 2016
    47
    12
    From your drawing, I am not exactly sure where the load is looking into, so I’m going to assume that the load is R3.
    Vth = V1 – V2 = 10V
    And Vth = R1+ R2 = 1K
    IL = Vth / (Rth + RL) = 10/ (1K + 1K) = 5 mA
    Hope this helps.
    Ashenrise likes this.
  3. HW-nut
    Member
    May 12, 2016
    47
    12
    Whoops, not supposed to answer the question. Let’s try this again.
    Vth is the open circuit voltage, What is the voltage at R3 if R3 is removed from the circuit?
    Rth is the output resistance, what is the resistance across R3 if R3 is removed and the voltage sources are shorted?
    Determining the load current should be straightforward once the circuit is redrawn in Theveninequivalent form.
  4. Ashenrise
    May 2, 2016
    I understand now, thanks so much, I used multisim to check it again and your answers were there, I don't know why I didn't get it the first time. Anyway, I appreciate the help greatly.
