check maximum current
Discussion in 'General Electronics Chat' started by foxhenry, Apr 23, 2009.
  1. foxhenry
    Mar 27, 2009
    15
    hi, how to check the maximum current flowing in a circuit? thanks..
  2. recca02
    Apr 2, 2007
    1,211
    By 'check' do you mean measure or calculate?
    You might want to elaborate a little.
  3. foxhenry
    Mar 27, 2009
    15
    calculate..thanks..
  4. recca02
    Apr 2, 2007
    1,211
  5. foxhenry
    Mar 27, 2009
    15
    hi, thanks for that link..the circuit has a crystal with 12mhz,,one IC, and some caps, resistor and inductors..how to calculate the max current.. thanks... :)
  6. recca02
    Apr 2, 2007
    1,211
    You will need to draw a ckt diagram with the IC simplified to represent a ckt. You will need to know the values of inductors, resistors,etc.
