A while ago I mentioned Maker Space.They have quite a few interesting toys, er, tools. Their 3D printer is kept busy making parts for other 3D printers.Tht 3D thingy..!
inkjet printer....hmmmm... what if you could convert a printer into printing a "plastic" circuit onto a pcb for etching? with a custom nozzle for an extruder, I'm sure you could manage to print some very fine traces.....This would be a separate thread worth pursuing IMO. A lot of old inkjet printers are used to make personal 3D printers.
The rostock Delta 3D printer I believe is pretty much still a prototype in Beta testing stage, there are others (Check out the RepRap WiKi) that you could build then print other machines for your friends, etc.Tht 3D thingy..!
Not true. As long as its for your own use(not for sale) and is not full automatic or a "destructive device" (over .50 cal) you can make whatever your heart desires. No applying for a license or informing ATFE. All that is needed on the gun is a serial number that you make up, your name and address, and the caliber of the gun.If you "manufacture" a firearm, or reciever(that's the part with the serial number) you must fill out a form and apply for a serial number from the BATF (Bureau of Alcohol Tobacco & Firearms). This is only valid only if you are making it for yourself. You must do this before you manufacture the reciever.
You do not want to get caught with one that has no serial number.
2 min late
You got different info than I did. I was a class I dealer from 1982 till 1996, my info comes from the Atlanta office. According to ATF a serial number is for tracing a weapon, just making one up and not notifying ATF does no good at all, as the number wouldn't be on record anywhere (according to ATF) You are , of course, 100% correct about the class III and destructive device stuff. The info I got was that no work was to be done untill a serial # was issued. A serial number must be affixed to any reciever that is more than 80% ( I believe that's the proper number) complete.Not true. As long as its for your own use(not for sale) and is not full automatic or a "destructive device" (over .50 cal) you can make whatever your heart desires. No applying for a license or informing ATFE. All that is needed on the gun is a serial number that you make up, your name and address, and the caliber of the gun.
I went to my local ATFE branch and got the law book before making a .22 cal Gatling gun and three AR15 receivers from scratch. Just to make sure it was legal.
I was just about to mention that. It's called the "lost wax process".for that to work the filiment would need to melt out of the casting.
Delta is a cool system for high speed pick and place on conveyor belts, but its a poor choice for 3 axis CNC machine. A linear XYZ give much better accuracy especially when real world objects benefit from having straight lines, and better still when those straight lines correspond directly with an XYZ axis.The rostock Delta 3D printer I believe is pretty much still a prototype in Beta testing stage, there are others (Check out the RepRap WiKi) that you could build then print other machines for your friends, etc.
You could also get a less "cool" one (not a Delta) for around $600.00 ...
Most of Rugers pistols and revolvers are made from the lost wax process.I was just about to mention that. It's called the "lost wax process".
So I'm seriously considering one of these 3d printers. I have about $1k to put into it. I would like to work with metal but thats not a deal breaker. My main uses would be to cut 2mm-3mm CF sheets into 2d parts. I would love to find an ABS or type of filiment I could print with, then make a cast with. But for that to work the filiment would need to melt out of the casting. Any other idea's? I don't wanna start from blueprints. I would consider a kit if it had a large community behind it, otherwise I'd like to go RTR.
by Aaron Carman
by Aaron Carman
by Jerry Twomey
by Duane Benson
