I want to check the resistance between pins of a TTL IC with my analog multimeter which has X10K ohm range giving 12Vdc(inside got 12V battery),I do not know whether the 12V batt voltage will damage the TTL IC (which only can stand or supplied by 5Vdc) or not?
