Cheapest switching regulator configuration
stoopkid
Joined Mar 3, 2011
146
I'd like to replace my 7805 with a 5v out switching regulator. My inputs will likely not be outside of 7-12v and I certainly do not need more than 1 amp any time soon. So I'm wondering if I should go with an IC or use transistors to make the cheapest switching regulator possible. I'm hoping less than 2 or 3 dollars. A specific part number or schematic would really help me out.
bountyhunter
Joined Sep 7, 2009
2,512
Cheapest would be a 555 timer and discrete driver cranking a cheap buck regulator, but it's not that easy. The easy way would be an LM2575.
30,807
Find a 5V switching supply used to power consumer electronics. You can find them at electronic surplus stores or second hand stores for less than $5.
panic mode
Joined Oct 10, 2011
2,750
Question for THE_RB:
I don't expect LDO but this looks so simple and neat, it got me curious. Did you try it at different supply voltages? What is reasonable range?
regards
PM
THE_RB
Joined Feb 11, 2008
5,438
Yep it works for a wide range, and that is one of its big advantages with the right Q1 transistor you can use it for a higher voltage input like 60v or 70v in 5v out, a range very hard to find in cheap SMPS chips.
Resistor choices are important if you change the input voltage range especially if you want to keep efficiency quite high. For that reason it's not a great SMPS where the input voltage varies within a large range. However that can be fixed easily enough by adding a 3rd transistor to keep Q1 base current constant (when on).
People have built the 2 transistor version to work from 110v mains input (170v DC) with the right resistors and a high voltage Q1. However I won't publish details of a 170v version due to forum regulations and safety issues. If someone is a professional who is allowed to work with mains equipment then they are capable of working out the parts values themselves. AND even then it means that every part of the circuit would be considered live at mains potential and possibly lethal. So don't do it.
