Hi all!
I have a piece of eqipment that needs a power supply of 2 x 18vac at 1000ma.
The said eqipment is famous for broken down power packs, and they are almost £50 TO BUY!, so I thought that I would just build one.
I have obtained a new transformer with 230v primary and 2 secondaries (0 - 18v).
Is it as simple to just box this and connect?
The equipment takes a 3 pin plug, so do i connect the 0v's together then wire to earth, and then wire the two 18v to the other 2 pins?
