Cheap good ways to measure into the high mHz to low ghz range?
Discussion in 'General Electronics Chat' started by jarwulf, Dec 4, 2015.
  1. jarwulf
    Jul 7, 2013
    60
    Hi I'd like to measure waveforms ranging from the low ghz to mhz range. Unfortunately almost all the oscilloscopes I've looked at seem to only go up to 50mHz to 100mHz before becoming prohibitively expensive. At least I'd like something that could go up to around 200mHz. Would a chinese USB scope like this
    http://www.ebay.com/itm/HDSO-100-50...020637?hash=item1c56c7d35d:g:0RcAAOxycmBSp~13
    be a good deal?
    It claims to have a bandwidth of 100MHz - 349MHz. Does that mean it can't measure below 100mhZ?
    Should I get a spectrum analyzer instead to measure into that range? Even though those seem even more expensive. Is their any other alternative type of instrument that I could substitute?
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    If you are not interested in the shape of the signal, but only its frequency, you could have a look at a frequency counter.
    Bertus
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You just don't understand the complexity of measuring anything at those frequencies. To be a lone RF Engineer requires equipment more valuable than most people's houses. Short of winning the lottery, you might have some luck on eBay or one of the rental companies. Most of the stuff coming off rental is in pretty tough shape however. At those kinds of prices it is easy to get taken as well. Last option is to cultivate an FAE who might tip you off to somebody getting rid of a piece of equipment on the cheap.
  4. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,850
    1,317
    If you don't require storage, new/NOS readout CRO's having half-power bandwidths of 500MHz are available for ≤ $8k --- they'll last a lifetime in skilled hands!:):):)
    Best regards and good luck
    HP
  5. kubeek
    Sep 20, 2005
    4,691
    806
    Not many people come to terms with extremely low frequencies, are you really sure you are talking about milli Hertz (mHz) and not about Mega Hertz (MHz)?
  6. Hypatia's Protege
    Mar 1, 2015
    2,850
    1,317
    As an aside -- unless you are analyzing transients, waveform characteristics (i.e. harmonic content, etc...) at VHF and above are better (and more economically) examined via an SA (AKA -- at risk of appearing pedantic --a frequency domain oscilloscope)...
    Best regards
    HP:)
  7. Aleph(0)
    Member
    Mar 14, 2015
    358
    347
    HP Is $8,000 cheap?
  8. Aleph(0)
    Member
    Mar 14, 2015
    358
    347
    HP If you are meaning rise and fall times when you say transients I say spectrum analyzer ok for that too! Is less intuitive for that purpose but you can save a lot of money:)
    Hypatia's Protege likes this.
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    If he was talking about low frequencies the terms would be millihertz, microhertz, nanohetrz, and picohertz. I think the OP/TS like many text speakers can't be bothered to use the shift key. I guess we won't be getting to Mars anytime soon.
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    To an RF Engineer it is peanuts. To the rest of us maybe not so cheap.
  11. Hypatia's Protege
    Mar 1, 2015
    2,850
    1,317
    For 500MHz bandwidth!? -- Dirt cheap!
    I respectfully submit that "expensive vs. inexpensive" is relative to the product -- not the parsimony of the purchaser!:rolleyes: --- Should one fail to regard proper instruments as worth their FMV then their 'heart' is not in their work/avocation -- my $.02
    Best regards
    HP:)
    Papabravo likes this.
  12. spinnaker
    Oct 29, 2009
    5,102
    1,190
    I think Papabravo said it a million times better.
  13. Hypatia's Protege
    Mar 1, 2015
    2,850
    1,317
    Respectfully $8K is a great price for the described scope whoever the purchaser... If I seemed to be taking issue with @Papabravo 's comment - I apologize - that was not my intent!:rolleyes:
    Best regards
    HP
