Would you sketch out a power feed circuit for the mike assuming 9 V power supply?See? "But an electret mic needs a preamp with a voltage gain of 100 to 400."
Adding one capacitor to an LM386 power amp IC boosts its voltage gain to 200 which is a lot of gain. Then the horrible mic preamp IC you have is not needed.
And what value caps do you suggest for the input and output to/from the LM386?
Thanks.
