Cheap and simple RF amp for signal generator
Discussion in 'Wireless & RF Design' started by Ziplock9000, Apr 14, 2009.
  1. Ziplock9000
    Apr 14, 2009
    I'm looking to build a low power (within legal limits) RF power amplifier that will alow me to connect my signal generator (as the carrier wave):
    LODESTAR LGA101A AUDIO SIGNAL GENERATOR
    and a line-level audio input to make a simple AM transmitter.
    Apparently I can just use an op amp, rather than a MOSFET because of the low frequencies involved?.
    Can someone provide me with a circuit diagram and parts list?
    Appreciated, thanks.
    Signal Generator Specs:
    Output Voltage :5V Rms or more
    Output Distortion :400 Hz - 20KHz, 0.1% or Less
    (100 range for 1KHz)
    50Hz - 500KHz, 0.5% or Less
    Output Flatness :±1.5dB (refer to 1KhZ)
    Square Wave Characteristics
    Output Voltage :10V p.p or more
    Rise Time : 0.25 us or Less
    Duty ratio :50%± 5% (refer to 1KHz)
    External Synchronization Characteristics
    Range ±3% of Oscillator Frequency
    Input Impedance : 10K Approximate
    Maximum Input :10V Rms
    Output Characteristics
    Impedance :600Ω ± 10%
    Attenuator: 0dB,-20dB, -40dB in 3steps (accuracy ± 1dB at 600Ω Load)
  2. KL7AJ
    Nov 4, 2008
    2,047
    295
    A simple class-A common base amplifier can give you around 20 dB of gain over a wide frequency range. Good educational project.
    Eric
  3. Ziplock9000
    Apr 14, 2009
    How would I incorporate the two inputs (the carrier wave from the signal generator and the line-level audio input).
    Thanks.
    Are there any tutorials or reference materials that would be good for this.
    I've googled, but I don't know which solution is most suitable.
    Thanks.
