And you're representing that a hobbyist can build this for $100.00 or less. What a crock!
No. It claims "World-class accuracy of 1.96 meters!" So how is a hobbyist going to better that (by a factor of 50?) for $100?And you're representing that a hobbyist can build this for $100.00 or less. What a crock!
Yes, that would work as a beacon. Probably better to have multiple receivers than rotate one.Or identifiable IR beacons (flashed at different speeds by a '555 would be simple and cheap) and a rotating IR receiver on the bot, like a radar dish.
Provided the beacon is of the right type, it should be able to work. You want a beacon that you can transmit a pseudorandom bit stream of data from.Not sure I follow. Can this be made to work with only ultrasonic beacons?
by Duane Benson
by Jake Hertz
by Duane Benson
by Duane Benson
