chassis to earth how?
Discussion in 'General Electronics Chat' started by williejon, Mar 2, 2013.
  1. williejon
    Feb 18, 2013
    11
    I need some help with an old box power supply. (40's, 50;s Welsh Scientific 2606k 12 dc / 24 ac) I have no schematic but it appears to have no on/off switch which is a problem. It also has a circuit breaker which I do not trust. I simply want to take some measurements if only for its noise and cycle hum. I tried to draw (below) some grounding alternatives but need expertise. I don't want to get bit. So, I have questions about polarization and protection.
    1) add a strip with breaker on the line in (unlike where I drew the fuse.
    a) make sure it breaks the whole circuit
    2) add ground to both chassis and earth
    Here is where I am stuck. Can I come off the core? How do I come in and out of the transformer? Thanks for any suggestions.:)
  2. ErnieM
    Apr 24, 2011
    7,434
    1,625
    I'm not sure of your question here, but a chassis connected to earth ground is as safe as one can get.
    Isolating from ground is less safe.
  3. williejon
    Feb 18, 2013
    11
    ψ thank you
  4. williejon
    Feb 18, 2013
    11
    Thank you. I'll rethink the isolation
