Chassis mount 3.5mm stereo plug
Discussion in 'General Electronics Chat' started by tracecom, Dec 11, 2011.
  1. tracecom
    Thread Starter AAC Fanatic!
    Apr 16, 2010
    3,878
    1,396
    Does anyone have a source for 3.5mm stereo plugs (not jacks) that are designed for chassis, panel, or PCB mount? I need something like the plug that's on the second generation Apple Shuffle charging stand that I can mount on a panel or PCB.
  2. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I've never seen a 3.5mm plug (male) in panel mount, but an easy solution would be to buy a normal male plug and unscrew the plastic casing, then the metal plug part (that has the thread) can be screwed into your panel.
    It sounds delicate, 3.5mm plugs are breakable enough without sticking out of front panels!
  3. tracecom
    Apr 16, 2010
    3,878
    1,396
    After looking one over, I think it might work. Hole size will be critical, and it would be nice to have a nut on the back side. Thanks.
  4. crutschow
    Mar 14, 2008
    13,477
    3,362
    If the panel is thin you can use a nut or the shell to hold the plug in the panel. I've done that with RCA plugs.
  5. tracecom
    Apr 16, 2010
    3,878
    1,396
    I have made an inquiry to CUI regarding the nut size for their SP-3501. I think it may be M8 X 1.0, but I'm not sure.
  6. mcgyvr
    Oct 15, 2009
    4,787
    973
    I'd get one with a metal knurled shell (casing) and drill the right size hole to press fit it into. (just slightly smaller than the OD of the plug)
  7. tracecom
    Apr 16, 2010
    3,878
    1,396
    I may have to do that. CUI did confirm that the threads are M8 x 1.0, but I haven't located a source for mating nuts.
  8. THE_RB
    Feb 11, 2008
    5,435
    1,305
    If you buy a male plug with a metal outer casing, you can cut the threaded end of the casing, to make a usable "nut".
    Also you might want to check metric pots, from memory I think their nuts are 8mm with a fine thread.
  9. tracecom
    Apr 16, 2010
    3,878
    1,396
    You are correct; the nuts are 8mm with a fine thread. In fact, it's too fine for the plug threads. It must be M8 x 1.25 if the plug threads are M8 x 1.0. (I assume the 1.25 means 1 1/4 threads per mm; correct?)
  10. KJ6EAD
    Apr 30, 2011
    1,426
    363
    No. The 1.0 means that each thread is 1mm. For example, 1.25 would be a coarser pitch. SAE threads are defined as the number in an inch while metric threads simply state the width of an individual thread. The two methods are reciprocal concepts.
  11. tracecom
    Apr 16, 2010
    3,878
    1,396
    Thanks for the info. That makes me wonder what the threads from the pot actually are. When I measure them with my (inch only) dial caliper, it looks like .031" thread spacing, which would convert to .787 mm. Maybe they are M8 x .75?
