Chasing LED's Activated by LED voltage.
Discussion in 'The Projects Forum' started by darkninja462, Jan 20, 2012.
  1. darkninja462
    Jan 16, 2012
    5
    I need to create a chasing LED circuit which is activated/signaled, by a smaller LED circuit (LED, power, ground @ ~3.0volts).
    I am hoping to have at least 10 Blue LED's 5000cmd, 3.2 lead voltage, 20mA (not sure if that is needed).
    and can either be running on 5,7,12volts.
    Regards
    -Ninja
  2. praondevou
    Jul 9, 2011
    2,936
    489
    Can you post a circuit you have in mind?
    What does "LED, power, ground @ ~3.0volts" mean?
  3. darkninja462
    Jan 16, 2012
    5
    Well it needs to use the HDD activity LED as a trigger, so it is the HDD LED circuit I was referring to.
    Regards
    -NInja
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
