Charging voltage
Discussion in 'General Electronics Chat' started by superway, Jan 3, 2012.
  1. superway
    Thread Starter Active Member
    Oct 19, 2009
    128
    I have a DC electronic load and a DC power supply. I would like to set current limit on DC supply with 5A, 7A , 9A step to charge 4 batterries 54.5V. Can anyone show me how to setup the load and DC supply to get current limit? On the DC supply, there is a current limit pot and voltage adjust pot.
    Ken
  2. MrChips
    Oct 2, 2009
    12,636
    3,455
    Set the voltage to 54.5V. Connect the batteries.
    Increase the current setting until the current reading reaches 5A or stops increasing, which ever comes first. Your DC supply will now be both voltage and current limited.
  3. superway
    Oct 19, 2009
    128
    Thanks Mrchip.
    But batteries are very low discharing now. When applying 54.5v to batteries, it will draw alot current from batteries and it might be more than 5A at initial charge. So that's why i have to use DC electronic load first to set initial charge 5A. My question is how to adjust current limit on power supply with electronic DC load connected to DC supply output ?
  4. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    What is the role of the electronic load? If the ps has voltage and current settings it would seem the answer is none. Do you really have a 50 + volt supply at 9 amps ( 450 watts? )
  5. superway
    Oct 19, 2009
    128
    Specs for initial charge is 5A @ 54.5 vdc
    For second charge cycle is 10A @ 53.5vdc.
    But my batterry string is read only 30Vdc. So I have to base info specs above to charge my batteries 5A @ 54.5Vdc. For initial charge, do I have to adjust the PS about 35vdc and increase gradually or adjust to 54.5vdc immediately?
    My current limit pot on DC supply just the pot with the label 20% to 120%.
  6. crutschow
    Mar 14, 2008
    13,502
    3,376
    Just do the adjustments as stated in post #2 by MrChips. If you start with the minimum setting on the current limit pot and increase it until it reaches 5A, then the current will never exceed that, no matter what the battery voltage.
