charging the series of cells
satyendra kumar
Joined Nov 20, 2011
Hi all,
i made a ckt which can detect the voltage for a cell(very common using differential opamp).i placed each ckt on each cell.and connected cells in series.
now the problem is, ckt is giving proper value of cells only when number of cells are 6 or less than 6.as soon as i am exceeding the number of cells more than 6 , the ckt does not give proper value of vltage..
to power up the ckt , i used vrps and all the ckts are connected in parallel.
can any one help me in this regard.:)
bertus
Joined Apr 5, 2008
22,278
I found this thread in "the completed projects" forum.
That forum is ONLY for completed projects.
There it will stay invisible.
I moved it over here and made it visible, so others can give replies.
Bertus
Adjuster
Joined Dec 26, 2010
2,148
You might guess that when enough cells are added in series, the total voltage of the battery they make up exceeds the span that can be accommodated by the circuit inputs, especially given that the description seems to say they are powered by a common supply.
We will probably never know though.
bountyhunter
Joined Sep 7, 2009
2,512
I bet it's gone out of the common mode range of the op-amp since it's only got a single rail.
