charging supercap through transistor
Discussion in 'Power Electronics' started by mikewax, Oct 3, 2016.
  1. mikewax
    Apr 11, 2016
    55
    this may seem like a really dumb question, but the transistor dynamics just make my head spin.
    i've wired it up like this:
    5v-----12ohms------npn------1Fcap------G
    the npn is switched from an I/O pin like this:
    pin(5v)-------1kohm-------base
    according to an online transistor calculator, i can't get more than about 90mA through the transistor (2n2222a) with this circuit. i need like 4 times that much current and i need to be able to switch it on and off from the arduino. does anyone know about this?
    thanks, mike
  2. #12
    Nov 30, 2010
    16,705
    7,358
    It takes two.
  3. wayneh
    Sep 9, 2010
    12,403
    3,250
    If you use a logic-level MOSFET transistor as a switch, your current is limited by only the 12Ω resistor instead of the base current for the transistor.
  4. mikewax
    Apr 11, 2016
    55
    talk about senior moments, i had a whole senior day. THANK YOU expert and wayneh, i'll order the MOSFET and use the stacked BJTs in the meantime. now i can get back to work. :)))
    one more thing though. if i gate the MOSFET with an analog output pin(0-5v), can i thottle the gate-source current up and down? i'll write a routine that will read the capacitor voltage through one pin, calculate dV/dt, and then increment/decrement the voltage on the gate pin untill the dV/dt is equal to some constant value. sound like a plan?
  5. Alec_t
    Sep 17, 2013
    5,980
    1,138
    The FET current changes dramatically with only a small change in gate voltage around the Vgs(threshold) value, so you would need a very fine resolution D/A output to give adequate current control. A bjt might be a better option than a FET for that purpose.
  6. mikewax
    Apr 11, 2016
    55
    OK i'll try it thanks. :)
