Can anyone point me in the right direction?
I want to set up a charging circuit for a 9 volt battery which will charge once the battery level is 5v and stop when it reaches around 9.
I want to run the charging circuit off an alternator which will only come on when the battery needs charging and once the battery is fully charged the alternator will switch off.
The battery is running a small circuit which can function from 5 - 12v. Hence only charging once it drops to 5v
Is this possible? and does anyone have any examples or circuits.
