charging capacitor
Discussion in 'General Electronics Chat' started by TAKYMOUNIR, Feb 10, 2012.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
    there is high voltage power supply (very high voltage up to 100 kv) we use it for charging capacitors, my question why we do not use the power supply direct to do the function of the capacitor if not(i mean we can not use power supply instead of capacitor) why we use the capacitor,and what kind of application that use the capacitor with very high voltage charge
    thanks
  2. Robert.Adams
    Feb 16, 2010
    112
    5
    I'm not sure what you're saying. Do you mean that you charge up the capacitor with the 100 kV and then turn of the source and allow the capacitor to power a circuit?
    Otherwise the capacitor is probably just across the source to smooth out the supply. The source still supplies the power and the cap just shunts away high frequencies.
    EDIT: Also, if you're just charging the cap, do you move it into a circuit to use it later? I imagine it would be difficult to safely take the cap from the source and make a circuit with it.
    TAKYMOUNIR likes this.
  3. ErnieM
    Apr 24, 2011
    7,435
    1,625
    There are two reasons off the top of my head why to use a cap:
    The cap may be used to get an instantaneous bust of current far larger then the power supply is capable of.
    The cap absolutely limits the total energy to about (.5*C*V^2)
    As far as typical applications such as these, the ones I am familiar with are for electrostatic discharge (ESD) testing where a capacitor C is charged to a certain voltage and discharged into something under test thru a resistor R to simulate a human finger zapping something.
  4. TAKYMOUNIR
    Jun 23, 2008
    351
    thanks very much you got what in my mind
  5. holnis
    Member
    Nov 25, 2011
    50
    Basically, when we have a system and have a high power surge from bass, like the brief hard hits, the capacitor let's loose some energy to compensate and help save the battery. very quick. then charges back up.
  6. BillB3857
    Feb 28, 2009
    2,402
    348
    Sounds similar to a photo flash system. Low current high voltage source charges a cap and the cap provides a high current surge to the flash tube.
