What is the capacity (Ah) of the 12V battery?
What are the capacities of the 5V batteries?
What is the chemistry of the each of the batteries?
What can I do to give it voltage little higher than 5V ?chargng a battery requires a higher voltage ( lok up battery specs) than the battery is rated for. a 7805 will give you 5 volts, your battery needs a little more to charge.
I would use the automotive cigar-lighter plug charger designed for your cell phone. It is designed to make the right charging voltage/charging current starting from a 12Vdc input. Much more efficient than using a 7805, which will waste 14W in heat to deliver 2A at 5V (10W) to the cell phone.5V battery is not actually of 5V its a cell phone Li Ion battery of 3.8V which needs 5V and 2 ampere to charge.
But i dont know about capacity of 12V battery. Its dry cell battery.
Does the 12V battery look like this?
Be sure to use the phone's built in charger - overcharging lithium batteries can cause "venting with flaming gas" or possibly a small explosion.5V battery is not actually of 5V its a cell phone Li Ion battery of 3.8V which needs 5V and 2 ampere to charge.
Buy one...Also suggest me a circuit to charge this 12V battery from 220 AC input.
Lead acid chargers can be tricky - I believe the transformers are specially wound to produce a particular current curve - the alternative is some circuitry that isn't trivial.Buy one...
by Jeff Child
by Duane Benson
by Aaron Carman
by Jake Hertz
