Charging a Lithium Battery via USB
Discussion in 'The Projects Forum' started by StealthRT, Sep 3, 2010.
  1. StealthRT
    Thread Starter Active Member
    Mar 20, 2009
    223
    Hey everyone, i am looking into a project that i want to be able to charge a Seiko MS621FE-FL11E lithium coin 3.1v battery.
    I will be using the 5v from the USB and convert it to 3.3v using the LM3940. However, i am not sure what all i need between the 3.3v and the battery itself. Is there some type of protection that is needed so that the battery will not explode? I would also like to incorporate an LED that flashes when its charging and also stays lit when charging has completed.
    I've been looking at the chip MCP73833 but it looks to output (charge) with 3.7v. If that is ok to use with the 3.1v battery itself then i can omit the LM3940 and just use the MCP73833 chip with 5v to the output (charging) of 3.7v to the battery. It also has output for LED's to show status! Sound good?
    Any help would be great! :)
    David
  2. StealthRT
    Mar 20, 2009
    223
    Anyone at all know anything?
    David
  3. marshallf3
    Jul 26, 2010
    2,358
    201
    Not a clue without full specs on the recommended charging method for that specific battery. You may find that you have to limit the 3.7V down a little but that would probably throw everything else in the circuit off.
    I also notice that Pin 8 is labeled THERM, sounds like a safety that shuts the charger down if the battery gets too hot.
  4. StealthRT
    Mar 20, 2009
    223
    Here is the datasheet on the battery:
  5. eblc1388
    Nov 28, 2008
    1,542
    102
    That 3.7V output from the MCP73883 is NOT acceptable as the battery datasheet specifically mandate the use of constant 3.3V voltage, current limited charging method.
    Unless you can reduce the output voltage of MCP73833, you'll need other solution.
  6. StealthRT
    Mar 20, 2009
    223
    Alright, well i looked into it more and decided to do this:
    Using a Dantona LIR2032 3.6V/40mAh Li-ion Rechargeable Coin Cell
    Using a Nordic nRF24L01+ chip to be powered. (the max says its max power is 3.7v)
    Using the MCP73833 to charge the antona LIR2032 3.6V battery
    nRF24L01+ datasheet with power specs:
    Dantona LIR2032 3.6V datasheet:
    MCP73833 datasheet:
    From the datasheets, it seems doable to use the MCP73833 to recharge the 3.7v dantona LIR2032 3.6v battery. But i'm no expert so that is why i posted my idea here of using this after reviewing everything.
    Please let me know if you see a danger/potential problem with doing this :)
    David
  7. StealthRT
    Mar 20, 2009
    223
    Any info/feedback on this? :)
    David
