hello friends,
i am thinking of project in which i want to merge two power source in a single lead acid battery one is the grid supply and other is the power from solar panel please any one can provide me the circuit diagram for this. actually i dont want to waste the solar power i am going to use 250 watt solar panel and a 12v 120ah battery for charging it, i want to run 2 fans and 2 tube light for 8 hrs in the absence of grid .
actually the problem in india there is a massive power cut we use to get a power cut in every 2 hrs for 3 to 4 hrs so the battery need at least 8hrs to charge i want to use both in the presence of grid i want both of them charge the battery and in the absence of grid solar panel should do its work . actually the planning is not to waste the solar power while grid is available.
eg: it is like if a battery need 230v of supply to charge and if i am getting 120v from the solar so i want rest of 110v only from the grid, by which i can save the electricity bill based on this consideration can any body help me and what r the other equipment i should have while constructing this project
