Hello.
I have a current transformer which senses the current that flows through the Live wire at home.
The transformer's output is connected to an IC which converts the analog signal into a matching number, and the IC serially sends the data to an Uc which wirelessly transmits the data.
The whole unit consumes 5V at 100mA (I have an option to remove addiotional components which the unit comprises and by that having the unit to consume 3.3V at 50mA).
I want to drive this unit with a chargable battery, and to be able to charge that battery with an electromagnetic force.
How can I charge the battery in that way?
Thank you.
It would be great if someone could refer me to inductive battery charging schematics.
Thank you.
