I made a post about having a motor that will not run of 5V. You guys said use a capacitor to start it. I know the motor will run off of the 3V battery (very well) that was inside the electrical screwdriver. So I am going to hook the battery to the motor. Though at the same time I want to charge the battery. So the motor is using the battery while the battery is being charged. I would have to use diodes? If so, where shall I put them.
Thanks,
Thanks,
