charging 12v from 12v but limiting current
Discussion in 'The Projects Forum' started by larry gardner, Aug 26, 2013.
  1. larry gardner
    Sep 17, 2008
    15
    Let me say I have read a lot in the past on the board but have not been on in a while. I have very little knowledge about circuits but find them very interesting. I have some one that can help me with this project locally after I get the information I need here.
    I fly electric RC Planes and want to charge 2 (140AH) deep cycle batteries (parallel) in the back of my work van. I do want to limit the current that they are charged at. Some where around 10 to 20 amps. ( not sure what the best charge rate is for deep cycle batteries. I assume lower is better)
    The idea is to have the circuit turned on by a auxiliary only while the van is running.
  2. wayneh
    Sep 9, 2010
    12,361
    3,220
    I'm confused. I assume you mean you DO want to limit the current? Are these lead-acid batteries?
  3. larry gardner
    Sep 17, 2008
    15
    sorry I edited that to say "I do"
    The batteries are lead acid batteires
  4. MaxHeadRoom
    Jul 18, 2013
    10,813
    2,491
    I am assuming you want to use the vans alternator to do this?
    Your vans alternator regulator peaks out at around 14.5v., the regulator maintains this regardless of load down to very low rpm's.
    The alternator current will vary dependent on the condition of the batteries, and any other load that may be on at the time.
    Have you considered just placing them in parallel with the Vans batteries?
    You could get a clamp on ammeter to do a trial with batteries that are in a fairly flat condition.
    Max.
  5. wayneh
    Sep 9, 2010
    12,361
    3,220
    You need to specify the charging current limit that you need.
    Have you measured whether there is a problem? I mean, if you just charged the battery off of your system voltage - like jumping another car's battery - does the current exceed the recommended rate for your battery?
    Also, can you tolerate a nice long charging time, for instance by limiting current to 5A or 2A or something much lower than the 10-20A? I guess I'm asking if you could live with trickle or float charging instead of bulk (high current) charging.
  6. larry gardner
    Sep 17, 2008
    15
    If deep cycle batteries can handle the charge from the vans charging system that would be great. I did not think that they could be charged at high amps. Im worried that after I discharge them at the field that the high charge rates on the drive home will damage the batteries.
    A trickle or float charge would be fine. Just wanting something to maintain them.
  7. MaxHeadRoom
    Jul 18, 2013
    10,813
    2,491
    Like I said, I would use a clamp on meter and actually find out what the charging rate is when fully depleted or after an extensive use, the current decreases rapidly as the voltage of the battery comes up.
    Max.
  8. wayneh
    Sep 9, 2010
    12,361
    3,220
    I agree - be sure you have a problem before trying to solve it.
    Or just put a cheap float charger on them when you get home. I believe those have internal self-protection circuitry so that, if the battery would otherwise draw too much current, the charger protects itself and won't deliver more than the 0.5A or whatever it was built for. This is one I have, got it for $5 on sale.
  9. strantor
    Oct 3, 2010
    4,302
    1,989
    I think your alternator is at equal or greater risk than the batteries.
  10. MaxHeadRoom
    Jul 18, 2013
    10,813
    2,491
    Assuming the Van battery itself is up to par, I don't see the alternator seeing any more load than it would with a normal low battery, I know alternators are rated for around 100amps, which is known to be impossible, at least for any length of time.
    But If there is an ammeter or readout in the vehicle, a sign the alternator is being taxed is the voltage will drop to around 13.2v. while the engine is running.
    Voltage is normally kept to approx 14.5v max. to prevent overcharging and gassing of the battery.
    Max.
  11. strantor
    Oct 3, 2010
    4,302
    1,989
    A normal low battery can kill an alternator all by itself, especially if it's normally low. If he had 2 deep cycle batteries in parallel with his existing battery, and they were low, that would mean (unless there's a diode separating them) that the original battery is also low. So three low batteries, two of them being deep cycle batteries, I'm pretty sure is going to tax the crap out of the alternator.
  12. MaxHeadRoom
    Jul 18, 2013
    10,813
    2,491
    I guess we are back to the old 'Clamp-on' Meter trick? :p
    Max.
    strantor likes this.
  13. strantor
    Oct 3, 2010
    4,302
    1,989
    That's probably the best advice we can give without crossing into the dark and forbidden "automotive modification" zone.
  14. MaxHeadRoom
    Jul 18, 2013
    10,813
    2,491
    I'm not sure I see anything being 'modified'?
    But that's just me :D
    Max.
  15. strantor
    Oct 3, 2010
    4,302
    1,989
    I see it the way you see it, but I know how some other people see it, and the decisions about whether or not to close threads generally favor their views. I'm just making predictions based on a long history of observation.
  16. larry gardner
    Sep 17, 2008
    15
    Thanks anyway guys this in not going in the direction I wanted.
  17. MaxHeadRoom
    Jul 18, 2013
    10,813
    2,491
    In what way? :confused:
    Max.
  18. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Agreed! But it's not too hard to deal with that.
    Just using the right size cable from the alternator (or van battery terminals) to the two deep cycle batteries in the rear of the van will add resistance, and the cable resistance can limit the peak charge current.
    Normally the problem is the other way around; vehicles that have a remote battery often have trouble that they cannot get enough charge current into the remote battery because of voltage drops in the cabling.
  19. strantor
    Oct 3, 2010
    4,302
    1,989
    if it's a low current trickle charge while driving that you want, consider something like this. But make sure to specify that you'll be plugging it into the cigarette outlet, lest it be considered an automotive modification.
  20. LDC3
    Apr 27, 2013
    920
    160
    I saw an advertisement for installing terminals in the trunk (or rear of van) for providing a connection for jump starting to avoid the hazards under the hood. I'm sure those wires would not have a lot of resistance.
