charger
Discussion in 'General Electronics Chat' started by sandeepjayan, Aug 11, 2013.
  1. sandeepjayan
    Aug 11, 2013
    can i charge 6v 4.5ah battery using Mosquito racket circuit.
    please help
  2. LDC3
    Apr 27, 2013
    920
    160
    If you don't mind taking forever and going through a ton of batteries. The 6V 4.5Ah battery has about 97KW of power in it. Each of the coin cell batteries in the mosquito racket circuit may only have 100W. Since you would need to increase the voltage of the 3V coin cell to at least 7 volts to charge the 6V battery, the amount of current available decreases as you increase the voltage. Also, the coin cell battery can only put out a limited amount of current (due to its size).
    Yes, it can be done, but it is not worth the time or expense.
  3. Shagas
    May 13, 2013
    802
    74
    Wat? 0.o
  4. LDC3
    Apr 27, 2013
    920
    160
    You're right, I was tired. It should be about 27 WH.
    But my point is valid in that it would take many coin cell batteries to charge the battery.
