I've been searching for days a way to charge a 12v acid battery so i can use it instantly just in case my power goes off.I found a circuit to charge using lm317, so far so good, ,but i can't use it as an alternative because the charger provides more than 12v, as i need exact 12v to put into an arduino pro mini. I will power my board from external 15vdc supply so i thought about using a relay to change what source of supply my circuit will use.ralay pin Common is the voltage that goes to my pro mini and other 12v stuff. problem is that 12vbat is not really 12v, as it's output charger that goes to battery. what can i do to use 12v from battery instead of 13.X charging circuit?
I appreciateView attachment 113638 View attachment 113638
