charge rate on rechargable batteries
clintonb
Joined Mar 6, 2011
52
I read that overcharging a lead acid battery is harmful for the battery. I have a battery charger that has an ammeter that shows the charge rate but i cannot seem to find any information on how this works(inclusing the manual!). Can someone please explain how this charge rate tells the state of battery charge?
thanks in advance
Clinton
debe
Joined Sep 21, 2010
1,390
Hi Clinton, The ampmeter doesnt tell you the state of the battery. you need to conect a voltmeter across the battery terminals while charging. The voltage will slowly rise while charging, if its a normal car battery i would stop charging when the voltage rises to about 14.5V no more than 15V.
Adjuster
Joined Dec 26, 2010
2,148
The ammeter mainly gives you confidence that charging is taking place, and at a reasonable rate. For instance, it would warn you if the current was nil or low because the battery clips were not making good contact. A persistent excessive current might indicate shorted cell(s).
Depending on the charger design, you might see some falling off of the current as the battery approached full charge, but if it happened at all this would only be a vague indication, and anyhow might be masked by mains voltage variations.
