Charge Pump
Discussion in 'General Electronics Chat' started by blah2222, Dec 31, 2013.
  1. blah2222
    May 3, 2010
    565
    33
    Hi all,
    In short, I am in need to create a single-ended supply for a high-voltage op-amp of around +50V from either a lithium (coin) or alkaline battery (AAs or 9V).
    Wondering if it would be possible to stack charge-pump (inductorless) boost converters in series to arrive at the desired voltage or if I need to go with an inductor-based boost converter.
    I have been looking at parts from TI for the sake of getting samples and the charge-pumps have outputs up to 5V which is a lot lower than I need.
    Any help is much appreciated.
    Thank you.
  2. ronv
    Nov 12, 2008
    3,393
    1,454
    I don't see why not as long as the current is fairly low. I would use the 9 volt option to reduce the number of stages.
  3. blah2222
    May 3, 2010
    565
    33
    Is there an IC that would get a 9V up to around 40V? Current won't be more than around 50 mA.
  4. tcmtech
    Nov 4, 2013
    2,110
    1,750
    Given the 50 ma requirement at 50 volts off of a 9 volt source the input load would be somewhere around 280 - 300+ ma.
    Getting to 50 volts form a 9 volt source with just charge pumps can be done but its going to take a fair amount of work to do. More than likely it would require a 6 or 7 stage system.
  5. ronv
    Nov 12, 2008
    3,393
    1,454
    If you really need 50 ma. you might be better off with a little boost converter. But either way it sounds like it is going to be more than what you were thinking about battery capacity wise. I'm having trouble visualizing a 50 volt 50 ma. op amp. Is it a power amp?
  6. ronv
    Nov 12, 2008
    3,393
    1,454
  7. blah2222
    May 3, 2010
    565
    33
  8. Potato Pudding
    Jun 11, 2010
    684
    92
    That can't be 50mA constant current. If that is more than a very low duty cycle max current pulse lasting for just a few milliseconds then you might not be talking about a good candidate for battery power. Even a 9V stack of 6 good D cells is going to struggle to run that power level for more than a minute.
    The charge pump route is not well developed for this purpose. There are reasons for that. I don't want to explain diode and adsorption losses.
    Just take some advice and use a boost switching converter. You should be able to find lots of help and resources on setting one up or even ebay a ready made module.
    blah2222 likes this.
  9. blah2222
    May 3, 2010
    565
    33
    Thank you for the reply. I guess I should have been clearer on my part.
    Output current: 50mA @ 30Hz with a 10us on time.
  10. Potato Pudding
    Jun 11, 2010
    684
    92
    Much better. 0.03% duty cycle is possible with battery power.
    To get that much current in a 10us pulse you will need a low inductance load.
    Was there a reason that you wanted to use a charge pump?
    Maybe you need to have super low magnetic signature or something like that; then sure use a charge pump because it can be done. Build it from discrete components if you need to.
    I stand by the recommendation of a switching supply solution otherwise.
  11. blah2222
    May 3, 2010
    565
    33
    I was just wondering if I could get away without using an inductor for this. I guess the concensus is to just use a boost converter with an inductor then?
  12. Potato Pudding
    Jun 11, 2010
    684
    92
    Your current requirements are very low. Your inductor can be very small especially if you are using a high switching frequency; anything over about 120kHz.
  13. #12
    Nov 30, 2010
    16,672
    7,314
    Did you forget that you can buy 22.5 volt batteries that are the same size as 9V batteries?
  14. blah2222
    May 3, 2010
    565
    33
    Couldn't of forgotten as I have never heard of them. Don't seem to be very common and I have lots of 9V lying around.
  15. #12
    Nov 30, 2010
    16,672
    7,314
    Being the same size as 9V batteries, you have to assume they carry about the same number of watt hours, but you can get to 45 volts with only 2 of them. They are still available at Mouser..I think.
  16. blah2222
    May 3, 2010
    565
    33
    Thanks for the suggestion. I will check out that option as well.
  17. blah2222
    May 3, 2010
    565
    33
    Could I not just use this MC34063A buck-boost-inverter regulator from TI?
    Seems to go up to 40V which is what I need. Anyone have experience using this IC?
  18. #12
    Nov 30, 2010
    16,672
    7,314
    I was wrong. The little 22.5V batteries are no longer available at Mouser.
    Edit: or any other place I can find.
  19. tcmtech
    Nov 4, 2013
    2,110
    1,750
    That's the way I would go. That IC and variations of it are used all over the place in small buck converters so I suspect they are pretty well designed and easy to set up.
  20. RichardO
    May 4, 2013
    1,336
    429
    This gives you no margin for tolerances and overshoot/ringing. You really need a part that has a switch with, more like, a 50 volt breakdown specification. I don't know of a single chip version off the top of my head. I do know that they are somewhat rare.
    It takes more parts but you may have to use a switching regulator "controller" that drives an external transistor switch.
