Charge pump circuit without gate driver
Discussion in 'The Projects Forum' started by sriniketh, Aug 28, 2015.
  1. sriniketh
    Jul 7, 2015
    29
    I wanted to make a IGBT high side circuit, with the help of reference
    diagram , i have made a LT spice schematic with charge pump design with
    out any gate drivers. The simulation worked fine and as i needed.
    But will the circuit will work without gate drivers ?
    kindly guide me through this .
    regards
    sriniketh
  2. Dodgydave
    Jun 22, 2012
    5,156
    772
    Can we have the circuit in jpg, or bit form.?..please
    sriniketh likes this.
  3. sriniketh
    Jul 7, 2015
    29
    I have uploaded a jpg version of the same
    thanks and regards
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    How do you actually make V1 and V3 float?
  5. sriniketh
    Jul 7, 2015
    29
    I am new to this field. i got reference from internet and made the circuit like this . i am not sure about the mistakes in this circuit. but the simulation with respect to the opening and closing of the igbt works as per my requirement. in the reference diagram attached, i have removed the top igbt and the second igbt i have connected the igbt source up and drain down.
    kindly help me in finding the error.the plot for gate voltage and the load current across the resistor of 5 ohm
  6. crutschow
    Mar 14, 2008
    13,505
    3,378
    How are you going to do the charge pump?
