Charge controller circuit project
Discussion in 'The Projects Forum' started by hovik, Sep 21, 2009.
  1. hovik
    Sep 21, 2009
    16
    I am making a control circuit for charging of a 12 V battery, and I'm having problems starting because I can't figure out how I could measure that the battery is fully charged.
    If I apply 12 V (DC) to the battery, and the battery becomes fully charged... the node with the applied 12V and the battery 12V will be the same... or?
    So how can I know?
    And also, if applied 14 V for charging the 12V battery... what would happen?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    A 12V battery is not 12V when it is fully charged.
    It will barely charge from a voltage as low as 12V.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Just saying "12V battery" is far too generic.
    Lead-acid, sealed lead-acid, NiMH, Ni-Cad, etc. etc... there are many different basic battery chemistries, and then there are different construction methods used within the various categories, and a wide variety of Ah or mAh ratings in each type.
    They all have different charge /maintenance requirements.
