I just build 2 wind propellers and made 2 dynamos out of trash.
My first dynamo is made of an old air condition in house ventilation motor. I just added 4 magnets in it and it gives me approx. 12 - 30 Volts.
My second dynamo is made from an old water jet pump motor case. I added 4 magnets around it's rotor. I added used washing machine water inlet coils. I used old construction iron bars to fill them and with a diode gate for each coil I have increased the efficiency.
Now this gives me approx. 20 - 40 Volts.
I try to add them to charge 12 Volt Battery(s)
I need an automatic cut off charge circuit where it will give the current out for the leds when in the night I will turn the led lightnings on.
Shortly; my electronic device has to help using battery as a first electric source, has to help the battery to charge from the wind and the sun ( off course I will add solar panels) and has to help battery to charge from the electric network.
I am planning to use
BATTERY MANAGEMENT SYSTEM (LTC6802 & ARDUINO)
Do you have advice(s) ?
Thank you very much for your time and interest.
