Charge 2x12V Battery
Discussion in 'General Electronics Chat' started by gpugelni, Oct 23, 2008.
  1. gpugelni
    Sep 6, 2007
    Hi all,
    I need your help with charging two 12V batteries (serial connection). I have two 12V 7.2Ah from FIAMM , it's lead acid battery.
    So, I need max. current and max voltage for charging two batteries connected in series because I need 24V voltage. Is it charge current of max 1.5, and charge voltage of 30V o.k. for charging, or should I use greater voltage, or should I charge batteries in parallel ?
    Thanks in advance,
  2. Bernard
    Aug 7, 2008
    4,236
    414
    I would charge them in parallel with a comercial charger.
