Charge 2 x 12v in parallel, draw in series as 24v
Discussion in 'General Electronics Chat' started by Roblaw84, Jan 28, 2015.
  1. Roblaw84
    Jan 28, 2015
    I was wondering whether it would be possible to have 2 x 12v batteries which are charged in parallel, but then the power is drawn in series to give 24v? I have sketched this using diodes and on paper it works but will diode actually work correctly in this manor?
    To give some background, Its for running a 24v diesel heater, in a campervan with 12v circuits and charging.
  2. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Welcome to the forum.
    Let's see your sketch, or at least a link to it ;)
  3. ErnieM
    Apr 24, 2011
    7,442
    1,628
    While you may possibly get this to work the results may be poor to very poor. The reason being ia the charge phase is best done by monitoring the voltage of the battery. With two in parallel you never see either batteries voltage correctly.
    Either get a 24V charger and leave them in series, or get two 12V chargers and disconnectof ro charging. </two cents>
    (Others may have done this and have better comments.)
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    It takes a DPDT switch or relay to do the switching (cannot be done with just diodes).
    Two lead-acid batteries of the same capacity and manufacturer (not other chemistries) can be charged in parallel.
  5. crutschow
    Mar 14, 2008
    13,509
    3,385
    Two identical lead-acid batteries charge okay in parallel since, even if one battery would charge up slightly before the other, the rise in its voltage from being charged, diverts the current to the other, which has a lower voltage from not being fully charged.
    But, as Mike noted, you can't do the series to parallel conversion just with diodes.
  6. bwilliams60
    Nov 18, 2012
    734
    94
  7. Roblaw84
    Jan 28, 2015
    Thanks for you help everyone.
