characteristic curve
Discussion in 'General Electronics Chat' started by superway, Oct 30, 2013.
  1. superway
    Thread Starter Active Member
    Oct 19, 2009
    128
    Please see my attachment, it is an input characteristics(orange lines) for a TDI DC electronic load. Can any one explain for me what if my data is inside the lines ( exp: 50A at 10V) and/or outside the lines (exp: 120A at 20V)?
    Thanks for help
  2. #12
    Nov 30, 2010
    16,655
    7,293
    I see something with a 50 volt limit, a 400 amp limit and a 2KW limit. That little nick out of the bottom right corner might be an indicator of inherent resistance of .00075 ohms.
    Typically, anything inside the orange box is allowable.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If your input falls within the outlined area, the device functions as an electronic load; if outside the outlined area, as a one-time-use smoke signal.
  4. superway
    Oct 19, 2009
    128
    Thanks for your help. Igot it
