Page 13: "A Josephson junction is a pair of superconductors bridged by a thin insulator, as in Figure below (b)" should be (a). (b) is the transistor.
Page 13: "Such an assembly in Figure above (b) is Josephson transistor." should read "Such an assembly in Figure above (b) is a/the Josephson transistor." (Missing article).
Page 13 Squid:Bibliography links ([JBa], [JBb], [JBc], [HYP], [DKB], [OXFD]) are all dead.
Page 14: "which is thin compared to the de Broglie (here) electron wavelength." Here is a dead link.
Page 14: Bibliography [PHA], [ERB], [GEP], [IGB], [PFS], [PHI], [RCJ2], [RCJ3], [AKG], [JWA], [MBR], [PNG], [DDA], [WJG], [IBM], [TLE] are dead links.
Page 14: "See CH 3 for details." CH 3 is a dead link.
Page 14: "The wells are so thin that electrons are confined to two dimensions. These are known as . A pair of these" Incomplete sentence.
Page 14: "be thin compared to the de Broglie (here) electron" Dead link.
Page 14: "overcome the isulator barrier." Misspelled insulator.
Page 14: "the probability of the electron wave everlapping from" Misspelled overlapping.
Page 14: "are separated by a pair tunnel barriers (insulator)," should read "are separated by a of pair tunnel barriers (insulator),".
Page 14: "This is single electron transistor similar to" should read "This is a/the single electron transistor similar to" (Missing article).
Page 14: "±1/2 the angular momentum (l)" Angular momentum is a dead link.
Gareth Williams
Gareth Williams
