Page 10: "which increases the cross-section area of the source-drain path." should read ""which increases the cross-sectional area of the source-drain path."
Page 11: "switch 100's of milliamp at near 100 VAC." should read "switch 100's of milliamps at near 100 VAC."
Page 11: "moving the PNP base toward of its collector voltage" should read "moving the PNP base towards its collector voltage"
Page 11: "in Figures above (b &c)" should be a space after the ampersand.
