Page 5: "Conduction of N-type electrons in the conduction band." should read "Conduction of N-type electrons occurs in the conduction band."
Page 5: "Moving a hole left to right, the electron must be moved right to left" should read "When moving a hole left to right, the electron must be moved right to left"
Page 5: "(b) P-semiconductor with holes moving left to right, which corresponds to electrons moving in the opposite direction."should read"(b) P-type semiconductor with holes moving left to right, which corresponds to electrons moving in the opposite direction."
Page 6: "In effect, we have nearly an insulator separating the conductive P an N doped regions" should read "In effect, we have nearly an insulator separating the conductive P and N doped regions"
Page 6: "The positive battery terminal attracts N-type electrons majority carriers away from the junction" should read "The positive battery terminal attracts N-type majority carriers, electrons, away from the junction"
Page 6: "The negative terminal attracts P-type majority carriers, holes away from the junction" should read "The negative terminal attracts P-type majority carriers, holes, away from the junction"
Page 7: "This and the Cu2O rectifiers were polycrystalline devices" should read "These and the Cu2O rectifiers were polycrystalline devices"
Page 7: "detecting giga-hertz radio frequency echo signals in the radar receiver.." superfluous second full-stop.
Page 7: "though sensitive to a wide bandwidth,," superfluous second comma.
Page 7: "Glass encapsulate small signal junction diodes are capable" I think this sould be 'encapsulated'.
Page 8: "
Page 8: "
