That would be my suggestion, even a simple microcontroller.But then we're on a road far away from KISS!
And a solid state logic solution would look good.
Yes now that I understand a little more what I'm looking at/for I do see they offer some bigger buttons with NO/NC and even some tri-color LED ones (ooo the posibilities )The supplier in your link has switches with N.O./N.C. and leds.
PM251/PM221
Even with another design, the N.C. for testing switch position/function seems best.
They are rated 2A 36VDCIf your mom button contacts are intended to switch the e-match current they should be rated for at least 1A DC. What is their rating? If less than 1A then you will need a relay or power transistor, controlled by the button, to fire the e-match.
I think the 2NO2NC is the most they can do on the 16mm button because of the size which is why you found the 4NO4NC in the 25mm buttonGo with the 2 of each.
There are different switch forms.
If you want a safety N.C. set that is isolated from the fire circuit, you need 2, of the form in the link. Like sw 1.
There is still a (slim) chance of a failure where a N.O. switch is stuck on and N.C. is not open..
See if they make a sw2 type. IMO
Looks like this is one, but 25mm.
http://www.aliexpress.com/store/pro...ch-PM251F-11E-B-2-8V-S/737142_1346384432.html
See the double break? 4sw terminals!
Might as well ask them again.
If your trying to confuse me YOU WIN! I think I need to sit down and digest this and not try to do that inbetween writing code and managing developers. Would also probably help if I had the different buttons and compnents to experiment with just to see how things respond.The most you should need is one N.O. and one N.C..
The issue is that often a circuit will require separate contacts. ie. No common!
Need access to all 4 terminals if you use circuit similar to my suggestion.
The 25mm showed this 4 terminal, single N.O./N.C. arraignment. This is the ideal contact form for safety switch.
The "2NO2NC is the most they can do on the 16mm" should be fine.
I'm splitting hairs!
I've done that when looking at old code I wrote.I'm sure that I'm making it harder than it has to be.
Maybe someone else could translate.
Sometimes when I go back to read what I posted, I can't understand it myself.
These two switch forms each have one NO and one NC.
But there is a difference!
The second has a common terminal. Because of that, the NO and NC part cannot be used in separate circuits.
To make up for that short coming 2 switches could replace the one.
Using the NO part of the first switch and the NC part of the second.
"want he 2NO2NC " Or the 1NO1NC with 4 terminals as in my link to the 25mm buttons.If I am understanding that correctly that is why you want he 2NO2NC buttons with 4 contacts so that the NO and the NC are seperated. Yes
When the buttons are not pressed and the current travels through the NO (NC) posts the turning of the key would latch the relay for the fire current so that when the button is pressed it would fire. Yes
Am I getting it or am I way off here?
by Duane Benson
by Don Wilcher
by Jake Hertz
by Duane Benson
